SGD$23.00
Features
• Heals dark undertone skin
• Heals dark scars
• Helps to reduce swelling and itch
• Reduce redness on skin
• Controls face oil that will form pimples
• Helps to tighten skin
Method of use
1. Use Cotton Pad to remove excess dirt (Exfoliating)
2. Gently Pat In With Your Hands (Hydrating)
3. Use as a Sheet Mask (Hydrating)
4. Let it sits into skin deeply with Cotton Pad (Hydrating , Pore Tightening)
GET SOCIAL WITH US
© 2023 Eyyrawrstore All rights reserved
